11 years agocustom instruction not working in 13.1.3
I have a simple combinatorial custom instruction that works fine under quartos 9.1. However (qsys in) quartos 13.1.3 doesn't generate the right logic. I've not tried quartos 14.x because I'm usi...
11 years agoI think this is a case where the documentation isn't explicit that you can't do it, but your use of 'b' is not what they were expecting.
Taking your code as-is, both Qsys and Quartus have warnings about 'b' (for example, "Explicitly unconnected" in the Quartus Port Connectivity Checks report). I'm using 14.0 but if you read the top-level Qsys file, you'll see the port not connected. If you add the 'readrb', the warnings go away and the port is connected in the top-level. Not sure if it will behave as you expect however.
