11 years agocustom instruction not working in 13.1.3
I have a simple combinatorial custom instruction that works fine under quartos 9.1. However (qsys in) quartos 13.1.3 doesn't generate the right logic. I've not tried quartos 14.x because I'm usi...
11 years agoMoving the xxx_hw.tcl file did require that it was edited by qsys and then hand edited.
Firstly to remove the unwanted 'clock' line then to add: set_fileset_property QUARTUS_SYNTH TOP_LEVEL I've just created the 'add immediate' instruction below - same problem.# TCL File Generated by Component Editor 13.1
# Fri Nov 14 15:38:04 GMT 2014
# DO NOT MODIFY
# add_imm "add_imm" v1.0
# 2014.11.14.15:38:04
# add immediate
# request TCL package from ACDS 13.1
package require -exact qsys 13.1
# module add_imm
set_module_property DESCRIPTION "add immediate"
set_module_property NAME add_imm
set_module_property VERSION 1.0
set_module_property INTERNAL false
set_module_property OPAQUE_ADDRESS_MAP true
set_module_property GROUP "Custom Instruction Modules"
set_module_property AUTHOR ""
set_module_property DISPLAY_NAME add_imm
set_module_property INSTANTIATE_IN_SYSTEM_MODULE true
set_module_property EDITABLE true
set_module_property ANALYZE_HDL AUTO
set_module_property REPORT_TO_TALKBACK false
set_module_property ALLOW_GREYBOX_GENERATION false
# file sets
add_fileset QUARTUS_SYNTH QUARTUS_SYNTH "" ""
# dsl - line below added by hand
set_fileset_property QUARTUS_SYNTH TOP_LEVEL add_imm
set_fileset_property QUARTUS_SYNTH ENABLE_RELATIVE_INCLUDE_PATHS false
add_fileset_file add_imm.vhd VHDL PATH add_imm.vhd TOP_LEVEL_FILE
# parameters
# display items
# connection point cis0
add_interface cis0 nios_custom_instruction end
set_interface_property cis0 clockCycle 0
set_interface_property cis0 operands 2
set_interface_property cis0 ENABLED true
set_interface_property cis0 EXPORT_OF ""
set_interface_property cis0 PORT_NAME_MAP ""
set_interface_property cis0 CMSIS_SVD_VARIABLES ""
set_interface_property cis0 SVD_ADDRESS_GROUP ""
add_interface_port cis0 ncs_cis0_dataa dataa Input 32
add_interface_port cis0 ncs_cis0_result result Output 32
add_interface_port cis0 ncs_cis0_b b Input 5
-- add_imm.vhd
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity add_imm is
port (
ncs_cis0_dataa : in std_logic_vector(31 downto 0) := (others => '0'); -- cis0.dataa
ncs_cis0_result : out std_logic_vector(31 downto 0); -- .result
ncs_cis0_b : in std_logic_vector(4 downto 0) := (others => '0') -- .b
end entity add_imm;
architecture rtl of add_imm is
begin
ncs_cis0_result <= ncs_cis0_dataa + (B"000000000000000000000000000" & ncs_cis0_b);
end architecture rtl; -- of add_imm
