13 years agoCustom Flash is not supported in Altera Qsys 12.0
Custom Flash is not supported in altera qsys 12.0, please let us know immediately, how to resolve this. we are using startix V FPGA
13 years agoyes, you can use your flash memory, i did it.
you must use 3 "components": Flash_generic_tristate_controller ^ | | tristate_conduit_pin_sharer ^ | | tristate conduit bridge It has been explained in an Altera PDF : look around Qsys and tristated component, be carfull of versions, make sure that you read for versions > 10.0 www.altera.com/literature/hb/qts/qsys_interconnect.pdf Unfortunately, you have to edit you custom Flash component http://www.altera.com/literature/ug/ug_embedded_ip.pdf 4. Common Flash Interface Controller Core When you edit your flash component, you must add by hand the lines in {I don't remember} Is memory device=1 Parameter=embeddedsw.configuration.hwClassnameDriverSupportList,embeddedsw.CMacro.SUPPORTS_FLASH_FILE_SYSTEM Value=altera_avalon_lan91c111:altera_avalon_cfi_flash,1 and in a place just below Parameter=embeddedsw.configuration.isMemoryDevice,embeddedsw.configuration.isPrintableDevice,embeddedsw.configuration.isNonVolatileStorage Value=1,0,1 Please have a look with legacy CFI Flash component already present. I spent 2 weeks to partially understand that and finally get my board work by "just working, don't touch ;-)" (no good work, no warranty) I post here MY file with absolutely NO WARRANTY EDIT : Make sure that your Qsys system is in your directory project (no subdirectory) : I posted on an ohter post for that inconvenient. Don't use space or "__" (double underscore) in your name, all lowercase (to avoid probable case sensitivity) EDIT 2 : For software (exactly BSP Board Support Package) That is not all :-P:-P:-P In Qsys-edit, you must tell that your component is a Flash by opting for the "good driver" in a drop down list. EDIT 3 : We like difficulties :p hope it can help you and if you succeed, make us aware.
