20 years agoCustom Components
I have created a custom component and incorporated VHDL code to define the components functionality. If I change the architecture of the VHDL code ONLY (i.e. the interface signals remain unchanged) c...
20 years agoIf you just copy the new vhdl sources to the project directory, they will be used when compiling the project(without re-generating in SOPC builder).
This does not affect the component, however. The files in the component's HDL directory are used, when you re-generate in SOPC builder. As Avishay said, if you change the interface of the component, it must be edited with component editor.
