21 years agoCustom Component
Hi, I created a 2-FIFOs with the following ports clk aclr wr_en data_in rd_en data_out empty(only on the source FIFO) one fifo will be the source and another fifo will be ...
21 years agoThanks for your reply BadOmen,
I like change my design to handle interrupts, I have a bit of a problem. I am a total noob with dealing with interrupts in C and how the interrupt signal should look like out of the VHDL code. Here is my VHDL code as of right nowlibrary ieee;
use ieee.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
ENTITY top_log IS
port(
i_clk : IN STD_LOGIC;
i_aclr : IN STD_LOGIC;
i_source_data : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
i_source_wrreq : IN STD_LOGIC;
i_cpu_rdreq : IN STD_LOGIC;
o_cpu_i_data : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
o_cpu_wait_request : OUT STD_LOGIC;
i_cpu_o_data : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
i_cpu_wrreq : IN STD_LOGIC;
i_dest_rdreq : IN STD_LOGIC;
o_dest_data : OUT STD_LOGIC_VECTOR(13 DOWNTO 0);
o_dest_rdy_to_rd_n : OUT STD_LOGIC
END top_log;
ARCHITECTURE rtl OF top_log IS
COMPONENT log_source_fifo
PORT
data : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
clock : IN STD_LOGIC;
q : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
empty : OUT STD_LOGIC
END COMPONENT;
COMPONENT log_destination_fifo
PORT
END COMPONENT;
SIGNAL c_dest_data : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL c_cpu_source_empty : STD_LOGIC;
type sm_wait_request_type is (s_waitrequest_init, s_waitrequest_okay);
signal sm_wait_request: sm_wait_request_type;
BEGIN
o_dest_data <= c_dest_data(13 DOWNTO 0);
LOG_SOURCE : log_source_fifo PORT MAP (
data => i_source_data,
wrreq => i_source_wrreq,
rdreq => i_cpu_rdreq,
clock => i_clk,
q => o_cpu_i_data,
empty => c_cpu_source_empty
LOG_DESTINATION : log_destination_fifo PORT MAP (
data => i_cpu_o_data,
wrreq => i_cpu_wrreq,
rdreq => i_dest_rdreq,
clock => i_clk,
q => c_dest_data,
empty => o_dest_rdy_to_rd_n
sm_wait_request_machine: process (i_clk, i_aclr)
begin
if i_aclr='1' then
sm_wait_request <= s_waitrequest_init;
o_cpu_wait_request <= '0';
elsif rising_edge(i_clk) then
case sm_wait_request is
when s_waitrequest_init =>
if c_cpu_source_empty = '0' then
sm_wait_request <= s_waitrequest_okay;
o_cpu_wait_request <= '1';
end if;
when s_waitrequest_okay =>
if i_cpu_wrreq = '1' then
end if;
end case;
end if;
end process;
end RTL; Right now the waitrequest signal goes high once empty signal from the source fifo goes low and the waitrequest signal doesn not go down to 0 until the last piece of data is written into the destination fifo. I can change the code back so it will send a signal to the cpu to tell it data is ready as you suggested in the above post. here is my c code #include <stdio.h># include <math.h># include "system.h"# include "altera_avalon_pio_regs.h"
int main (void)
double source_word;
double log_word;
double floor_word;
double upscaled_word;
while(1)
source_word = IORD(TOP_LOG_0_BASE, 0);
log_word = 10*log10(source_word);
upscaled_word = (log_word)*(pow(2,6));
floor_word = floor(upscaled_word);
IOWR(TOP_LOG_0_BASE, 0 , floor_word);
return 0;
} This code is meant to convert MHz into Db(10log10(Mhz)) and upscaled 2^6 so I will get the precision I need. how would i change this code and mapping in the custom component to implement interrupts? Thanks in advance!
