16 years agoCustom component writing to SD-RAM
Hi fellows, i have created a system in which nios II processor is running at 100 MHZ and ddr sdram is running at 150 mhz so , i also added a clock crossing bridge, after this i created a ...
16 years agoYou can add an Avalon master port to your custom component. Through this master port, you can write to and read from your SDRAM (or any other slave component). Components can contain more than one Avalon port including a mixture of both master and slave ports.
