22 years agoCustom boards and Firmware_ROM
Hello can anybody help me ? I have modified the NIOS II CFI-drivers so they now support an 8-bit CFI-AMD-flash device. Afterwards I have tested it using the "flash_tests"-program (through the N...
21 years agoHello cetic, no you're quite right. My modified HAL-driver wasn't the problem. In fact the compiler didn't take my modifications into account at all. The problems I had was caused be the PLL alone. I also installed some modified flash-drivers, but these didn't update the firmware_ROM. Sorry I can't be of more help there http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
A little thing to try: You say your flash-drivers work. Can you build an old fashioned Nios I application with a fully working GERMS-monitor? Because - I believe anyway - that would be a work around to writing to the flash since the NIOS II IDE seems to be generating flash-files too. When using the old Nios I we could burn the flash by using the command nios-run followed by the flash-file we wanted burned to flash. I do not know if the above solution will work ....remember I'm pretty new at this http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif but hopefully some of the experts can verify this idea. Hope you can make it work! Regards Goon
