22 years agoCustom board with epcs & cyclone error
Has anyone gotten a custom board to work with epcs 4 and a cyclone yet? I have tried for a week and can't get the cpu or flash programmer to work. It either comes back with an error 6 "Unable to ...
22 years agoNot clear on what does or doesn't work on your board.
I assume you have verified the devices are powered within spec, reset lines OK, and the master clock is present and clean. Do you have both a Jtag header and a header for the Epcs device? If so, can you program the Epcs device with active serial mode using its header? If not, are the data&clock signals to the device present and clean? Are the Jtag data&clock signals present and clean? Some serial bus designs benefit from adding small series resistors on these lines. Our custom board uses a cyclone with an Epcs1, but no configuration controller such as the kit board. I can program the Epcs via its header, and I can also use the Jtag header to run applications, configure the FPGA, and program flash using the flash programmer utility. What I cannot do (yet) is program the Epcs with the flash utility.
