16 years agoCustom Avalon-MM salve IP
Dear all I have an IS61WV25616BLL device on board and want to add a custom Avalon-MM salve IP to be able to use the ram. Here is my custom verilog code. But the interface won’t compile. Do you h...
16 years agoThe signaltap manual is here: http://www.altera.com/literature/hb/qts/qts_qii53009.pdf?gsa_pos=4&wt.oss_r=1&wt.oss=signaltap.
I don't see anything wrong with your code, but the problem could come from somewhere else (timing parameters in the SOPC component builder, as an example)
