16 years agoCustom Avalon-MM salve IP
Dear all I have an IS61WV25616BLL device on board and want to add a custom Avalon-MM salve IP to be able to use the ram. Here is my custom verilog code. But the interface won’t compile. Do you h...
16 years agoSo it's the first test. Can you use Signaltap to look at the signals to the SRAM and see if they are correct?
