20 years agoCS8900 Interface to NIOS II
Hi, I was hoping someone could point me in the direction of a description, hopefully including a circuit, specifying how the CS8900 should be connected to a Nios II. I searched the Alte...
20 years ago --- Quote Start --- originally posted by mike desimone@Nov 2 2005, 04:52 PM i'm pretty sure that uclinux doesn't care about or use altera's hal. it has its own drivers. altera's hal tries to simulate a filesystem, which is redundant in uclinux, where you have a real filesystem (not to mention an entirely different driver model).
that said, when you say uclinux has a driver for the cs8900, do you mean that there is support for the cs8900 under the nios ii/avalon bus architecture? i mention this because there are lots of drivers for the pc architecture that aren't compatible with the avalon bus architecture. the easy way to find out is to configure a linux kernel and see if there's an option for the cs8900.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10748)
--- quote end ---
--- Quote End --- This is exactly the information I was after, thank you! Yes, there is specifically an option for CS8900 when configuring a uclinux kernel. There are a number of options, including some of the IP Mac's and some more established devices, I think I recall the RTL8019 as well. Thanks again! Paul.
