20 years agoCS8900 Interface to NIOS II
Hi, I was hoping someone could point me in the direction of a description, hopefully including a circuit, specifying how the CS8900 should be connected to a Nios II. I searched the Alte...
20 years ago --- Quote Start --- originally posted by victors@Oct 31 2005, 10:08 AM i currently have nios1 designs using the cs8900 but it appears that nios2 does not like it very much. for some reason it cannot access the interface correctly.
i also don't think there is hal support for the cs8900.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10697)
--- quote end ---
--- Quote End --- I think I was a little careless in my question, I should have been a little more specific : My final aim is to run uclinux, which I note has a driver included for the CS8900. Therefore, if I connect a CS8900 to a Cyclone implementing a Nios II, on which I run uclinux, will it not be able to use the CS8900 without modification? Paul.
