21 years agoCross Compiling problems
In short, I'm trying to get EPICS ported to linux over NiosII. The folks at Argonne National lab already have EPICS running on linux over x86 architectures. Among the many cross compiling probl...
21 years agoEven though you're working under Cygwin, I'd be careful with how you're capitalizing your filenames. Try ensuring that you're using a ".s" extension instead of a ".S"
If you're still having a problem, drop down to the commandline and try running make for your kernel but add on "V=1" to your commandline arguments to make. This will force verbose output to be on (which will show each command being run). If you're having problems running from the commandline, let me know and I'll post the commands that you need here in the forum.
