19 years agoCreating SYSLIB sets all files read-only
For our project, all the Quartus/Verilog code is in one directory tree (C:\Verilog), and the NIOS C code is in another tree (C:\MyProject). (Running on Windows 2000.)
In order to use the C2H accelerator, in the NIOS project we create a SYSLIB by referring to the PTF file under the other tree -- C:\Verilog\nios_0.ptf. When we then do a build, it sets all files under c:\Verilog to read-only. Then when we try to accelerate one of the C functions, and the build tries to re-compile the hardware description, it fails because everything is read-only. Is setting everything read-only the expected condition if you build a Syslib by referencing a PTF file in another directory tree? Should we combine everything into a single tree in order to support C2H accelerators? Is there another setting we can change to fix this? Thanks for any assistance. So far C2H has been annoying!No RepliesBe the first to reply
