12 years agoCreating static library without bsp
I need to create a simple static library to be linked with my main NIOS-II application. I don't want to have that library be dependent on BSP, because it is purely software logics. Is there a built-in way to achieve this with NIOS II SBT eclipse? I'm using NIOS-II SBT 12.0. Thanks2 Replies
In menu, I think, you get New>library.
Nios II SBT is designed to be used with material boards. That is why BSP is needed : it matches hardware and software. But you can create simple application without NIOS II. Can you give an example of what you want to do ? - Altera_Forum
New>Library option requires BSP.
My intention is to build a NIOS II application which depends on some utilities which are compiled as static library. These utilities are not hardware based but pure software based. This is why I want it created without the BSP. An example utility can be something that manages strings.
