11 years agoCreating pof from sof and two hex - exceeds memory
Hi, I am trying to generate an EPCS64 pof file with sof and two hex files. One hex is my nios code (relative addressing). The second hex (absolute addressing with 0x7F0000 offset) is a tiny 64 cha...
11 years ago --- Quote Start --- .. ok thanks... so if you use absolute for your nios code are you manually entering the address to be directly after the sof? Or do you have a custom bootloader that jumps to know address? Both these I was hoping to avoid.... --- Quote End --- I'm using the chain of commands (sof2flash, elf2flash, objcopy) from this article: http://www.altera.com/support/kdb/solutions/rd10132010_126.html i.e. use those commands to dynamically figure out where to put your NIOS code
