11 years agoCreating pof from sof and two hex - exceeds memory
Hi, I am trying to generate an EPCS64 pof file with sof and two hex files. One hex is my nios code (relative addressing). The second hex (absolute addressing with 0x7F0000 offset) is a tiny 64 cha...
11 years agoThanks. Looking at the map file I can see that when I add the second hex file its placing the nios code after it and thats the reason for memory exceed.
So it seems using the Convert Programming File utility will place a "Relative addressing" hex at location after other hex files (not just after the sof). Hex Data Nios -- Relative addressing -- <auto> Hex Data Tiny -- Absolute addressing -- 0x007F0000 Sof Data -- Page_0 -- 0x00000000 This results in the Nios code being placed after 0x7F0000... I cant seem to change the priority in Convert Programming Files... So the question now becomes: How do I include two hex files and keep the nios code as relative addressing directly after sof and then add another hex file with absolute addressing after that?
