12 years agoCreating Multicore system using NIOS2 command shell
I have created a multicore system and downloaded the .sof file on the DE1 board using bios command shell. Now i am trying to create th ebsp using command "nios2-bsp $BSP_TYPE $BSP_DIR $SOPC_DIR --cpu...
12 years agoHello I have solved the issue and issue was with the addressing of peripherals in Qsys.
Now, I have been hardly trying to run the 3 cores simultaneously but I am not able to do so. I have 3 cores and i just programmed the three cores to continuously print "Hello World" with some delay. When I download code in 1st core, it starts printing successfully. But when I do it for 2nd core, the 1st core stops printing. Why is it so. Ideally, 1st core should print as soon 2nd core is done printing once. I have managed the timing to print so that they don't overlap while printing the same time. Help is really appreciated
