14 years ago
Creating Memory device for Nios II processor
I want to transfer data from my custom component to the processor. Ideally it would be possible to access the data using pointer. Normally I would have to use IORD and IOWR macros to circumvent the caching of the processor.
I plan to implement the interface as an Avalon MM slave interface. If I add a new memory device in the "Linker Script" section will it it possible to access the region using pointers then?
Can I declare the interface as an memory device in the TCL script of my component?
Are there any prerequisites to use the interface as a memory device, e.g.:
-must the interface expose both a read write port (I only want to read data from the interface)
-does the interface have to support pipelined transfers, bursting?
Best regards
Martin
    Short update if anyone stumbles upon this thread. I've attached my module as a memory device to the Nios II processor. The magic is that you have to define the device as a memory device in the _hw.tcl script.
    Before reading from the device you have to flush the processor read cache for that memory region:
    alt_dcache_flush_no_writeback((void *) <address of burst IF>, <length of burst IF memory region in bytes>);
    Martin
