13 years agoCreating Ethernet Frames
I've got an Aria V starter board with Marvell PHY. I'm trying to get some data from the board to the PC over the ethernet. The QSYS system is all wired up and I can do DMAs from an internal memory ...
13 years agoAh thank you, I am using wire shark and not getting good frames on the PC. But I didn't realize the 2 byte offset was necessary. Does anyone know where this is documented? I actually figured out the 2 byte offset by trial and error but would like to read about that offset from some Altera literature if it exists.
