16 years agoCreating database using nios II
I got one ADC which is used to convert analog data from sensor to digital data. The digital data will be stored into FPGA. it contains approximately 10,000 of data. I am thinking to integrate my system which contains nios II+jtag uart+on-chip memory using SOPC builder. Can I use the nios II processor to create worksheet in PC so that other engineers can view/analyze data easily? Any suggestion on how to do it if this way is possible? Any others idea to do it if this way is not possible? I hope someone can response me since I have ran out of idea. Thanks for quick response.1 Reply
Hi
You can transfer the data from FPGA to Nios II processor using PIOS and send it out using JTAG terminal But i dont know whether you can write the data directly from NIOS II to a text file in PC instead of displaying on JTAG Terminal & than copying to a text file Can someone tell whether we can do that regards M Kalyansrinivas
