21 years agoCreate a new componet(Avalon tristate)
1) As the components are share the system data/ address bus in the custom board, so we should "share" the bus. Then we found there is no "place" to set "is share " opition, only in the "trista...
21 years agoDo you use an 8, 16 or 32-bit data bus off-chip?
In any case, I would suggest you use Native (Registered) mode, and connect the SOPC A2 signal to the A0/RS0 on the LCD controller device. "Wasting" a few addresses like this is completely irrelevant. Your code would then do: IORD_8DIRECT(LCD_base,0) IOWR_8DIRECT(LCD_base,0,data8) IORD_8DIRECT(LCD_base,4) IOWR_8DIRECT(LCD_base,4,data8)
