21 years agoCreate a new componet(Avalon tristate)
1) As the components are share the system data/ address bus in the custom board, so we should "share" the bus. Then we found there is no "place" to set "is share " opition, only in the "trista...
21 years agoI use "New componet" to create LCD module(quartus 4.2 Nios II 1.1)
(1) LCD module: RDn, WRn, CSn, Data[7..0], A0 In the custom board, A0 is connected to Avalon's tristate address[0], which is shared by SRAM. (2) SOPC components: LCD Interface: Avalon tristate slave Addressing: Memory signal name_______type__________direction RDn_____________readdata_n_____in WRn____________writedata_n_____in CSn_____________chipselect_n____in Data[7..0]________data__________inout A0______________address_______in It will share Data[7..0] and A0 in tristate bus automaticly. (3) The result is not work now. Some questions: (3.1) is it the problem of using IORD/IOWR in such way: IORD_8DIRECT(LCD_base,0) IOWR_8DIRECT(LCD_base,0,data8) IORD_8DIRECT(LCD_base,1) IOWR_8DIRECT(LCD_base,1,data8) causing multi-times read/write cycle or the address not diving by 4? (3.2) If I change it to register addressing, is it conflect by "A0 is connected to Avalon's tristate address[0]" ( should connected to Addrss[2])
