20 years agoCPU overload when reading UDP packets in NIOS1
Hi fellows
My application periodically in a loop (with period 20ms) receives about 200byte long UDP packets and normally the CPU load (computed from /proc/stat info...) remains around 1 or 2%. But when another demanding app. is started concurently with my app., then the CPU load sometimes raises to 100% ! Even more, when the priority of my app. is driven to realtime SCHED_FIFO type, then the app. halts another processes until it is killed or no packets are incoming from outside. I tried variety of functions - blocked read(), select() function, real-time signals (SIGIO), also tried to switch on kernel preemtion support, but nothing changed.. Even with simple blocked read() I got the same results - incredibly high CPU load. I think the problem is hidden somewhere in the kernel (maybe in process scheduler). I will be very pleased, if you give me some hints and suggestions about kernel or about my application, to get low and stable CPU load. ---- I use: Altera cyclone board, original LDK with NIOS1, uClinux environment for NIOS1 and kernel boots from FLASH, where the ROMDISK filesystem resides.. --- thanks, janNo RepliesBe the first to reply
