16 years agocpu not found
Hi there, This issue has been posted by someone else in the General Altera section of this forum but I thought I'd post it in here as it is more of a Nios issue. Basically I am getting thi...
16 years agoAfter 2 days of messing about I have finally found the reason for this error, so I shall post my fix for all those who may stumble across the same issue.
All you have to do is go into your main project folder and move/delete any pre-compiled *.sof and *.ptf files from it, including any backup versions you may have under the same name. While you are at it you can also delete the .sopc_builder folder as well as the sopc builder will re-generate that file when you run it again. Rebuild the IP in sopc builder, rebuild the hardware in Quartus. Launch Nios II and do a clean and a build. I hope this may help anyone who is stuck with the same compiler error.
