20 years agoCoverting/Combining SOF and ELF for EPCS
I have developed a NIOS II module with some of my custom made components. It synthesizes into a .sof file. I develop some C code to run on this particular core. This is compiled into an .e...
20 years ago --- Quote Start --- originally posted by slacker@Aug 28 2006, 08:38 PM <div class='quotetop'>quote
--- quote end ---
--- quote start ---
do you know if there's a way to initiate fpga (re)configuration cleanly from software/firmware ? (alt_shoot_yourself_in_foot perhaps) --- Quote End --- Most of the Altera designs do this by using the "reconfig_request" PIO. On the Altera boards, this pin is connected to a small design in an on-board Max device. Though I've not tried it, you should be able to do something similar by routing your nConfig pin to another I/O pin on your FPGA. Cheers, - slacker <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17915)</div> [/b] --- Quote End --- Well, to my (slight) surprise, and credit where credit is due, I got a very prompt and clear response from Altera on this (raised SR early yesterday), basically confirming everything Andrew says above - always nice to get the same answer from two sources. My confusion over the Flash Programmer User Guide is as much mis-reading as anything - it's not obvious throughout the doc that flashing the bootloader is only needed for CFI Turns out the ability to re-configure "on demand" is present on Stratix/Stratix II/GX chips which have a dedicated remote config control block. Not much help to me with my already manufactured Cyclone II-based design, but hey-ho ..... Hey guys - thanks a LOT for the valuable help ! Alan
