20 years agoCoverting/Combining SOF and ELF for EPCS
I have developed a NIOS II module with some of my custom made components. It synthesizes into a .sof file. I develop some C code to run on this particular core. This is compiled into an .e...
20 years ago --- Quote Start --- originally posted by queisser+aug 25 2006, 05:38 pm--><div class='quotetop'>quote (queisser @ aug 25 2006, 05:38 pm)</div>
--- quote start ---
<!--quotebegin-ghavenga@Aug 24 2006, 03:41 PM a ) control the offset in the epcs (or any flash) where the software is placed. this is different from where it's going to be located once it's loaded into ram - we don't care about that - we need to specify put the software in the epcs at offset blah.
b ) tell the bootloader this offset.
c ) be able to tell where in the epcs the code is loaded from - from the application itself. if this is not possible, we could use the hard coded value from step "a", but it would be really nice to figure that out for step "a" and then have everything else just configure automagically.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17819)
--- quote end ---
--- Quote End --- Greg, not sure why you want to do this - it would be easier to reserve space for whatever you want to do inside your firmware image or at the very end of everything. I'm assuming that you want to keep the FPGA config and some other data together in the EPCS and change the firmware image independently of those other two items. Keep in mind that the EPCS is two things: 1) a magic device to load FPGA configuration. If I'm not mistaken the FPGA automatically loads from EPCS starting at offset 0 so you can regard that as a given 2) a general purpose serial flash device where you can write and read (using the HAL flash API) whatever you want following the FPGA config. To address your questions: a) I haven't tried this but you should be able to use the flash programmer to write any location in the EPCS, given the right command line options. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif The bootloader in question is part of your NIOS design. I think it's inside the EPCS component so you'd have to dig up the sources of the bootloader (e.g. components/altera_nios2/sdk/src/boot_loader_sources/boot_loader_epcs_bits.S) and modify it to boot from a specific address instead of directly after the FPGA config file. I could envision different ways of configuring that address but the simplest approach would be to write some additional bytes directly following the FPGA config bytes that say "skip n bytes to get to the beginning of the image." If you haven't done so already, take a look at boot_loader_epcs_bits.S. I think this is the code that ends up in the EPCS component itself and is compiled into the FPGA configuration so that's where you'd have to add code to support the reserved gap you're after. I haven't looked at how the bootloader ends up inside the FPGA configuration image but it must be part of the SOPC compile process. c) Once you've modified boot_loader_epcs_bits.S you should have some fixed location inside the EPCS component itself that you can read with normal I/O operations. Again, I haven't done this but I can't see why it shouldn't work. Good luck and keep us posted, Andrew <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17847)</div> [/b] --- Quote End --- I also want to programme EPCS from code already running from RAM (receiving the new code via a network interface). I'm not too worried about separating FPGA code and NIOS code, but I AM confused by the boot loader : 1. Is the boot loader code always the same ? (so doesnt vary with .elf section sizes and locations etc) 2. How does the boot loader code get programmed ? API ref says its read only at the first 256 words of the EPCS map - how are these accessible ? do they overlay the start of the "real" flash array ? The docs imply the bootloader lives in a ROM, which is part of the EPCS controller on the FPGA (not in the EPCS), however its clearly programmable, as the code file is a parameter to elf2flash.... 3. So what I'm really asking is : if I want to re-programme FPGA code and/or NIOS ROM code from NIOS (RAM) code, what do I do about the boot loader to make sure my new code gets properly copied to RAM ? AlanB
