20 years agoCoverting/Combining SOF and ELF for EPCS
I have developed a NIOS II module with some of my custom made components. It synthesizes into a .sof file. I develop some C code to run on this particular core. This is compiled into an .e...
20 years agoHi,
> Where on the EPCS controller do I write this data? > What offset/address should I use? The device configuration starts at offset zero. The (binary) flash contents start immediately after the configuration data. If you want to look at some sample code that shows how to find the end of the configuration data, take a look at the epcs bootloader code (assembly) or the epcs code in u-boot ©. Regards, --Scott
