14 years agoCould not read 8 bit data from custom ram
Hi every body! I'm a newbie in SOPC system design. I'm trying to create a custom ip, which has an internal RAM (declare as an array) and contacts with NIOS via Avalon MM bus. I'm using D...
14 years agoI would recommend making your slave have 32 data bits - even if the top 24 are ignored on writes and return 0 on reads.
An 8 bit slave will always see 4 bus cycles when the NIOS doe a byte access to it. On writes three of theses will have the byte enable de-asserted. However the NIOS always asserts all 4 byte enables on reads - so you'll see 4 separate read cycles for each cpu byte read.
