RPALO3
7 years agoCould not able to get the output of ADC in max10 board. The ADC toolkit(Beta) is not instrumented in system console.
can you suggest how to download the hardware setup for ADC toolkit.
YuanLi_S_Intel
7 years agoHI Ritu,
It seems like not a problem with Quartus, it would be the quartus design problem. Regarding to the ADC IP setting, i would suggest to refer to the guide at link below:
https://www.youtube.com/watch?v=0oO1RFa-4Xk
It is tested and proven to work. Also, you mentioned about the hardware not detected, have you connected your board to PC via USB Blaster? Can you check if the connection is established between PC and your board?
Thank You
RPALO3
7 years agoyes, I am using USB Blaster. Let me figure out the error again. Thanks for your help.
