11 years agoCostas Loop oscillates in ModelSim while locks in MATLAB!
Hello again, I have designed a Costas Loop in MATLAB and it simulates very well... locking and recovering the carrier. Here are the results: http://www.alteraforum.com/forum/attachment.php?...
11 years ago --- Quote Start --- If you want a tricky solution then avoid loop altogether and do the following: apply a known tx symbol pattern at start. Try detect it at Rx. Keep moving phase offset until you get it. That is all. In practice this trick wouldn't work or I will have patented it since frequency needs lock as well. --- Quote End --- Eventually I am going to attach RF Front-End and receive the signal... plus, this is a graduation project as you know and I can't trick professors :D Although they might not know anything but I really want to do it for the sake of self satisfaction :)
