21 years agoCorrupted .cdtbuild files
I've just been bitten badly by the NIOS IDE 'make manager' again.
A system library which I was using fine yesterday suddenly failed to compile - gcc failing with a "cannot specify -o with -c or -S and multiple compilations" error. The generated makefile had a line reading "CFAGS = null ", and selecting the C/C++ build options for the system library properties dialog showed be a 'blank' page without any of the usual options. Turns out the libraries '.cdtbuild' file had been trashed, and was missing vital sections. I had to manually copy them from another system library project. The corrupted one looked like this:-<?xml version="1.0" encoding="UTF-8"?>
<ManagedProjectBuildInfo>
<target artifactName="My_syslib.a" cleanCommand="rm -rf"
defaultExtension="a" id="My_syslib.nios2.lib.80040364"
isAbstract="false" isTest="false" name="Nios II Library">
<configuration id="nios2.lib.release.86196347" name="Release"/>
<configuration id="nios2.lib.debug.1347398883" name="Debug"/>
</target>
<defaultConfig id="nios2.lib.debug.1347398883"/>
<defaultTarget id="My_syslib.nios2.lib.80040364"/>
</ManagedProjectBuildInfo> Any thoughts on how to avoid this? - Also, is this the right forum to post bug reports like this in?? - Roddy1 Reply
I ran into a similar problem a few days ago. What fixed it for me was to delete the project (but not the files) then re-import it into the IDE. Can't remember if I had to reset any values after that. I didn't analyze the corruption so I'm not sure if it was more or less corrupted than your file.
