13 years agoCorrection to Makefile
Hello, I have found projects that contain library dependencies always relink to create the final ELF file even if nothing has changed. Although this isn't wrong or bad, it does cause creation ...
12 years agoHmmmm .... I should have checked the manual! I've clearly not written enough makefiles recently.
It seems I meant $^ not $*. Since the makefile is echoeing the commands, you could use : instead of echo
