20 years agoCorrect procedure for changing the clock speed
The Timing Analyzer reports that my fmax is 70MHz. So if I want to run at 70MHz, is this what I do? 1) In SOPC Builder, change clk to 70.0, then regenerate. 2) In the sdram_pll, change the in...
20 years ago --- Quote Start --- originally posted by bkucera@Mar 21 2006, 11:27 PM the timing analyzer reports that my fmax is 70mhz. so if i want to run at 70mhz, is this what i do?
1) in sopc builder, change clk to 70.0, then regenerate.
2) in the sdram_pll, change the inclock0 input to 70mhz. click finish and update the component
3) recompile
the output clocks are running at 1/1 so they should operate at whatever inclock does. is this the correct procedure for increasing the clock speed the board runs at?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13656)
--- quote end ---
--- Quote End --- Have you also set the input clk for your system to 70MHz?
