16 years agocopy performance in user space vs. kernel
Hi, I am using Linux 2.6.32 with MMU with DDR SDRAM and I've run into some performance issues copying data. Copying from DDR to DDR using memcpy in an application only gets me 6-10MB/s. Copyi...
16 years agoThe kernel used a stream-lined access, while the standard glibc didn't. You may adapt arch/nios2/lib/memcpy.c instead of glibc.
- Hippo commit b3eaa1c911109e99c6cd06ec9b91a86a34929fa6 nios2: memcpy with stream-lined memory access As sdram has long access latency, the total access time can be reduced with sequential access in the same page. This patch unrolls the copy loop and stream-lines the memory access as (read x8 + write x8) for aligned source and destination, or (read x4 + write x4) for unalinged, using registers for buffer.
