14 years agoConfiguring TSE & Nichestack
I have Quartus&SBT 11.1, and a board with PHY 83848. I cannot bring up the eth interface with simple socket example. SOPC configuration is good (i hope), but i can't initialize the software: ...
14 years ago --- Quote Start --- Are you really sure? AFAIK support for the lan91c111 was dropped by Altera ages ago. The examples use the Interniche TCP/IP stack, which has a driver for the TSE. --- Quote End --- The readme file say: DESCRIPTION: A Simple Socket Server that controls development board LEDs. Requirements: -RTOS Type - MicroC/OS-II -Software Component - NicheStack TCP/IP Stack - Nios II Edition -Period System Timer - SYS_CLK_TIMER PERIPHERALS USED: This example exercises the following peripherals: - Ethernet MAC (named "lan91c111" in SOPC Builder) - PIO, 8-bit output (named "led_pio" in SOPC Builder) - PIO, 16-bit output (named "seven_seg_pio" in SOPC Builder) - STDOUT device (UART or JTAG UART) It doesnt' say anything about TSE
