16 years agoConfiguring the System clock timer in system library
Hello, I am trying to configure the system library of a NIOS II IDE Application. In the system library contents, there is an option named "system clock timer" that can be set to none or to ...
16 years agoI would recommend that you clearly indicate in some documentation somewhere that you didn't put a system timer and what the consequences are.
You never know how projects evolve over time, and you may need to add a delay or timeout mechanism one day, and spend hours trying to find out why it doesn't work... ;)
