16 years agoConfiguring the System clock timer in system library
Hello, I am trying to configure the system library of a NIOS II IDE Application. In the system library contents, there is an option named "system clock timer" that can be set to none or to ...
16 years agoIf you don't have a system timer, some functions won't work. Functions such as sleep, all the time functions, the alarms... If you don't use them, you don't need to set a timer.
