21 years agoconfiguring a new system
whenever iam creating a new system on SOPC builder and then downloading the .sof file the following message is displayed while running a c/c++ application program Using cable "ByteBlaster I...
21 years agoDo you mean the 1C20 Full Featured reference design? If that's the case then you probably ran into the same PLL problem that joe98 encountered. So while you were having problems you were using the sof file that came in that project without compiling? Did you have to open the SDRAM PLL and change it to Cyclone for your compile to work or did you simply compile and that worked?
Cheers
