21 years agoconfiguring a new system
whenever iam creating a new system on SOPC builder and then downloading the .sof file the following message is displayed while running a c/c++ application program Using cable "ByteBlaster I...
21 years agoSo you downloaded the .sof to the target then tried to launch your application through the IDE – is that correct?
Are you sure your hardware is configured correctly? If you are using the dev kit try adding an output that will drive a LED or something that lets you know the processor is running.
