Configure NIOS firmware burning interface
1) JTAG Programming
In Platform Designer (formerly Qsys), if you're using a NIOS II system, you typically do not need to manually add a JTAG interface block. Instead:
The JTAG interface comes automatically when you add a NIOS II processor, and it is used via the JTAG UART or JTAG Debug Module (DM).
If you're looking for physical JTAG pin connections (TCK, TMS, TDI, TDO), those are part of the FPGA hardware design, not something inserted via Platform Designer. You handle them in the top-level Verilog/VHDL design or via the Pin Planner in Quartus.
To check or export JTAG pins:
Open the Quartus project’s top-level design file (e.g., top.v or top.qsf).
Use Assignment Editor or Pin Planner to assign JTAG signals to the correct FPGA pins (these are often automatically assigned depending on your dev board).
2) IRQ Column:
In Platform Designer:
The IRQ column (Interrupt Request) defines the interrupt priority or vector number when you connect a peripheral (like a timer or UART) to the NIOS II processor.
The number you enter (e.g., 1, 2, 3, etc.) determines the interrupt number that peripheral will use.
Rules:
Each IRQ number must be unique for each peripheral.
Lower numbers can be treated as higher priority depending on your interrupt controller setup.
Do you need to change them?
Yes, if you have multiple interrupt-generating components, assign each a unique IRQ number.
If your system only has one interrupt source, then you may just use 0 or any number as needed.
