21 years agoConfigure Kernell *Error*
This is the error:
------------------------------------------------ Microtronix Linux Extensions Version 1.2, Built Wed Jul 27 3:46pm EST 2004 ------------------------------------------------ make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com. microtronix.nios2linux.kernel_0.1.5/linux-2.6.x' HOSTCC scripts/basic/fixdep /usr/local/bin/ld: cannot open crt0.o: No such file or directory But i can not find de directory on my computer. Can someone help me ?3 Replies
Hi... try unmounting your /usr/lib directory...
you might have to tryumount /usr/lib
in order for it to unmount.umount -s /usr/lib - Altera_Forum
It's not working..
Is the command for umount not working? Or are you still getting the same error when trying to compile your kernel?
Could you pass me the results of running the mount command from within the Nios II SDK shell? Should look something like:C:\altera\quartus42\bin\cygwin\bin on /usr/bin type system (textmode) C:\altera\quartus42\bin\cygwin on / type system (textmode) c: on /cygdrive/c type user (textmode,noumount) d: on /cygdrive/d type user (textmode,noumount) z: on /cygdrive/z type user (textmode,noumount)
