22 years agoConfigure Kernel Problem
Hello, have installed the Linux PlugIn for the Nios II IDE and try to build a kernel as described in the "Quick Start Guide.pdf". Step "configuration" (page 9) fails: the "Linux Kernel Confi...
22 years agoTry using V1.1, which now available. If you're using V1.0, you need to install the windows NT patch posted under the distribution section (you'll need to increase the search time to 60 days).
