22 years agoConfigure Kernel Problem
Hello, have installed the Linux PlugIn for the Nios II IDE and try to build a kernel as described in the "Quick Start Guide.pdf". Step "configuration" (page 9) fails: the "Linux Kernel Confi...
22 years agoThe configuration.bat does not find the gcc!
------------------------------------------------ Microtronix Linux Extensions Version 1.0, Built Fri May 7 11:44am EST 2004 ------------------------------------------------ make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com. microtronix.nios2linux.kernel_0.1.4/linux-2.6.x' HOSTCC scripts/basic/fixdep gcc: not found make[2]: *** [scripts/basic/fixdep] Error 127 make[1]: *** [scripts_basic] Error 2 make: *** [menuconfig] Error 2 make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.m icrotronix.nios2linux.kernel_0.1.4/linux-2.6.x' c:\altera\kits\nios2\bin\eclipse>pause Press any key to continue . . . May there occur any problems, when cygwin was already installed on this system???
