21 years agoconfigure kernel fails
when i want to configure my kernel in the drop down menu, the window opens shortly and closes a second later. normally opens the blue configuration window, but here only the bash window for just a m...
21 years agoI've had a similar problem on a system on which a standalone copy of Cygwin was installed. I'm guessing that the uClinux installer found Cygwin and not Quartus' Cygwin, which led to some kind of problem finding gcc. I couldn't get Cygwin and Quartus Cygwin to coexist, so I uninstalled Cygwin, reinstalled uClinux, and it all worked.
If the installer asks you for the location of Cygwin, make sure you point it to Quartus II 4.0's Cygwin.
