15 years agoconfigure: error: --with-ldopts no longer supported; use LDFLAGS= instead
I'm trying to update from e2fsprogs 1.40.9 in my build to the 1.41.10 from the current.
So, I put the dir under the uClinux-dist/user/e2fsprogs dir and changed the ver= in the Makefile BUT It doesn't like the "--with-ldopts" in the Makefile ******* last part of "make" messages -L/home/janet/nios2-linux/uClinux-dist/staging/usr/lib make[4]: Entering directory `/home/janet/nios2-linux/uClinux-dist/user/ftp/ftp' make[4]: warning: jobserver unavailable: using -j1. Add `+' to parent make rule. make[4]: Nothing to be done for `all'. make[4]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/ftp/ftp' make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/ftp' [ ! -d "telnetd" ] || ( touch telnetd/.sgbuilt_user && make -C telnetd ) || exit $? make[3]: Entering directory `/home/janet/nios2-linux/uClinux-dist/user/telnetd' make[3]: Nothing to be done for `all'. make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/telnetd' make[3]: Entering directory `/home/janet/nios2-linux/uClinux-dist/user/sash' make -j1 -C libsash GEN /home/janet/nios2-linux/uClinux-dist/user/busybox/build-busybox/Makefile make[4]: Entering directory `/home/janet/nios2-linux/uClinux-dist/user/sash/libsash' make[4]: warning: -jN forced in submake: disabling jobserver mode. Using /home/janet/nios2-linux/uClinux-dist/user/busybox/busybox as source for busybox make[4]: Nothing to be done for `all'. make[4]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/sash/libsash' make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/sash' configure: WARNING: unrecognized options: --disable-shared, --without-shared, --disable-dependency-tracking, --enable-fast-install Generating configuration file for e2fsprogs version 1.41.10 Release date is February, 2009 checking build system type... i686-pc-linux-uclibc checking host system type... nios2-unknown-linux-uclibc checking for nios2-linux-uclibc-gcc... nios2-linux-uclibc-gcc checking for C compiler default output file name... make[4]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/busybox/build-busybox' make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/busybox' a.out checking whether the C compiler works... yes checking whether we are cross compiling... yes checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether nios2-linux-uclibc-gcc accepts -g... yes checking for nios2-linux-uclibc-gcc option to accept ISO C89... none needed checking for dlopen in -ldl... no configure: error: --with-ldopts no longer supported; use LDFLAGS= instead make[3]: *** [build-e2fsprogs-1.41.10/Makefile] Error 1 make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs' make[2]: *** [e2fsprogs] Error 2 make[2]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user' make: *** [subdirs] Error 1 [janet@localhost uClinux-dist]$ ******************** Obviously I'm not a "make" expert because I've tried things but feel lost. Could someone please help ? I've attached the "config.log" (config.pdf) too (Greek to me) Thanks !1 Reply
Please try the command
in your 'e2fsprogs 1.40.9' directory. You can get useful messages. And set the environment variable for the linker's flag like./configure --help
from your shell if necessary. Kazuexport LDFLAGS=****
