20 years agoConfiguration bombs at power up
I have a working design up and running in Quartus 5.0 SP1. I programmed a couple of boards with the image last week. They have been sitting on my test stand cranking away. In the mean time, I...
20 years agoI believe when using the EPC16 config device, you should specify the use of a compressed image in the options for each page in the Convert Programming Files tool. The issue really is that there are 2 different compression schemes, one that is in the FPGA itself (EG. CycloneII / StratixII), and another where the EPC16 itself does the decompression. The option you checked may refer to the first compression scheme which i don't believe is supported in the EPC16 device.
--dalon
