21 years agoconfigtool error
I just finished going through a terrible thrash in getting uClinux to run on my custom board. Painful, but eventually got it working with plenty of help from that forum. Now I'm trying to see i...
21 years agoUnfortunately I don't have an Altera board to work with, just our custom board. Is there a listing somewhere of all the required peripherals that are needed to allow an eCos kernel to build? BTW, this was an issue with the uClinux distro too -- nobody would publish the secret list of periperhals required to build that kernel, which made the entire process long and painful. I was hoping maybe eCos would be different.
Can you think of anything that might cause the configtool to hang in the way I showed? It was barfing on the system clock for some reason. It is set to 50 MHz in the SOPC builder -- is that the wrong value for the eCos distro? (though I can't see why the configtool would care what the clock freq. is) I'll add a timer and see if that allows the configtool to deal with the system clock. I appreciate your help -- thanks! TomB
