21 years agoconditional compilation ?
Hello. I'm working with two kits of development NIOSII. I wish to use the following conditional compilation in a common file (as user.h) : // --- choice of board ---------------...
21 years agoThank you for your answer
I have just used the command "File / Refresh" to 'refresh' my whole project. I have used the command "Project / Rebuild All". Unfortunately, there is no change. But I have just found this link on the ALTERA' s site : http://www.altera.com/support/kdb/2000/01/...32000_6557.html (http://www.altera.com/support/kdb/2000/01/rd01032000_6557.html) Could this explain my problem partly ? I tried to use the operators# if defined(...),# if !defined(...), ... same result Best regards. bbo
