20 years agoComponent Editor Error
When I try to add a simple file like the below in Component Editor it fails. ????????????? It happens for all file, more comleks than this eksample to. <div class='quotetop'>QUOTE </div> -...
20 years ago --- Quote Start --- originally posted by doofus64@Feb 9 2006, 12:01 AM the project i have, compile fine in quartus. and there is generatet logic out. i can se the logic in "chip editor". do any have an example project to try. i know there are i example in the tutorial for the soap builder, but i can't find it.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12650)
--- quote end ---
--- Quote End --- doofus64, The example and tutorial for the component editor can be found on the Altera literature web page. http://www.altera.com/literature/quartus2/lit-qts-sopc.jsp (http://www.altera.com/literature/quartus2/lit-qts-sopc.jsp) Chapter 5 covers the features of the component editor. http://www.altera.com/literature/hb/qts/qts_qii54005.pdf (http://www.altera.com/literature/hb/qts/qts_qii54005.pdf) If you look at chapter 9 it has the tutorial flow for building a pulse-width modulator. http://www.altera.com/literature/hb/qts/qts_qii54007.pdf (http://www.altera.com/literature/hb/qts/qts_qii54007.pdf) The design files for the tutorial can be found in the link below chapter 9. http://www.altera.com/literature/hb/qts/pwm_source.zip (http://www.altera.com/literature/hb/qts/pwm_source.zip) Regards, -ATJ
